lanti118
asked Jan 16, 2018 at 12:48pm
Brother Brother MFC 8680DN
running out of toner
How do I make the cartridge "thinks" that there is still more toner in it?
  1. Open the door and press the Clear/Back key.
  2. Press *00.
  3. Press OK.
  4. Do not choose anything for drum replacement. When the drum replacement menu comes up, press * and then 00, then press OK.
by moe on Jan 16, 2018 at 2:34pm Add comment
And another trick you can do is once the print has become very faded, pull out the toner cartridge and shake it side to side to re-distribute what toner is left. You can usually get at least 2 more pages each time you do this until it will finally use up all the toner.
by Samir on Apr 21, 2018 at 9:58am Add comment
