Donnieclark
asked Nov 14, 2017 at 2:48am
Acer Acer Other Vuego 406
Printer driver Canon Mutlipass C70 for XP
Hello,
I have a printer, scanner, fax, copier everything in one. The Canon Mutlipass C70. This device worked perfectly under 98se but since I have XP pro it does not work anymore. Have searched everywhere for drivers but nowhere to be found.Canon called and according to them I had to download the
drivers from win2000 from canon.nl and after installation the
patch of XP over it.Immediately after installation the printer works ok, but after
restarting the problems start.PC no longer sees the printer and the installation of the drivers can not be undone. At last so many problems with the PC (super slow) that I had to format. This tried 3 times but nothing helps.
Does anyone know a solution, or just
buy a new printer.
Well, the Multipass costs f700-. when I bought it
thick 2 years ago and used very little.
Thank you in advance
I didn't find the right solution from the internet.
References:
http://helpdeskforum.nl/viewtopic.php?p=4045908&sid=eab162c6ba5f62a5ebe4526babdbecdf
whiteboard animation
