lexiewilliem
asked Oct 12, 2017 at 5:23am
-1
Alwright Data Other Laser 6
How to compress excel file size
Most of the times we suffer from Excel hanging or opening issue due to its large size but do you know there are measures that you can take to reduce the size of Excel File. You can reduce the size of the pictures and Pivot table. Then remove any formatting from unused cell range and also remove unused content from the file. The XLSB file format automatically reduced the size. In fact you can take help from Professor Excel tool for this purpose or split or zip the workbook. If you don't have any idea how these functions are performed then take help from experts by dialing 0808-101-2159 Microsoft Support Number UK.
Thanks for your tutorial! It works!
Check this tool: json formatter online
by Dalton on Oct 25, 2017 at 4:13am Add comment
  1. With the Excel file open.
  2. Click on the File tab (Fig 1)
  3. Select "Save AS" from the Tab menu.
  4. In the Save As dialog select the "Save As Type" dropdown field and select the "Excel Binary Workbook (*.xlsb)" option from the list of values. See figure 2.
  5. Click Save.
  6. surveillancekart
  7. pestveda
by jacklynnvern on Dec 4, 2017 at 4:24pm Add comment
