W8SLC
asked Mar 17, 2017 at 10:06am
Hp HP Photosmart 5520 Wireless
Cartridge
I installed an OLD set of cartridges; got error message: DEFECTIVE, REPLACE.
Can the printer orifices be cleaned? They appear to be clogged.
THANK YOU
The cartridges have chips on them that the printer reads. The printer is built by Canon which means that the heads are removable. What you do is take out the ink tanks. To the right, you'll see a plastic lever. Lift it up and it releases the heads. Reach in and remove them. Take them to the sink and using hot tap water flush them from the top for 10 seconds and then flip it over and flush the bottoms for 10 seconds. Repeat a few times until the water runs clear. Dry off with a paper towel and reinstall.
by moe on Mar 18, 2017 at 4:38pm Add comment
