[email protected]
asked Mar 16, 2016 at 8:29am
Hp HP LaserJet 4100TN
pair of springs left over
I'm a novice at this. Replaced the transfer roller assembly, the separation pad and various rollers. When reassembled, both the paper tray and the manual feed are working fine. However, I found a pair of very small springs on the workbench when I was done - they are 3/4 of an inch long and have no hooks at the end. I have been unable to figure out where they are supposed to go. Any ideas? If everything is working without them should I even worry about them? Thanks.
I'm going to go with the separation pad. It has 3 springs. Just look at it and see if it has just the one spring in the center. I guess that must be enough to raise it into position. Easy enough to re-install the 2 that are left over. Just be careful not to lose 1.
by moe on Mar 16, 2016 at 5:41pm Add comment
