butch1e
asked Dec 4, 2015 at 12:34pm
Epson Epson WorkForce WF-2530
WF-2630 will not answer incoming calls
By the way my wf-2630 is not listed above..The machine will not answer incoming calls.
On the Epson WF all-in-ones you can set the FAX to automatically answer, answer after a certain number of rings (in case you have an answering machine), or to manually answer. Chaeck to make sure it is not set to manually answer...my WF reset to that and I spent a while trying to find out what was wrong with the cables, etc.
HTH,
Ocicat
by Ocicat on Dec 7, 2015 at 2:39pm Add comment
