asked Jun 17, 2000 at 2:59pm
Apple Apple LaserWriter 360
Apple LaserWriter Select 360
Hello, I'm needing to replace the two rollers in the fuser or the fuser itself. It gets hot, but one of the rollers has a groove worn down the center of it and the other one has creases worn into it and it passes these onto the paper, when it doesn't just jam the paper inside the fuser. Also the print quality is bad, as there is areas missing from the printout. I'm assuming this is all due to the wornout rollers in the fuser.
Thanks, Tony
Those are kind of hard to find. I have a good used core in the shop that's missing the fuser lamp. Let me know if you're interested.
by moe on Jun 17, 2000 at 9:39pm Add comment
