Tendmaz
asked Feb 9, 2012 at 11:28pm
Hp HP LaserJet 1200
HP 1200 Series
This printer came in for a Fuser film replacement but now Its printing faintly,smudging at other spots. If you rub your fingers against the print the ink is smudged as if ts not dry. http://www.fixyourownprinter.com/i/i/86.gif
It's a laser printer so it uses toner, not ink. I've seen those where the heater doesn't get hot for a few prints. Try running 3 or 4 sheets and see if it gets better. If it does, then you'll have to replace the whole fuser. It's also possible for you to have put too much grease on the heater surface. This has the effect of insulating the heat transfer to the sleeve.
by moe on Feb 10, 2012 at 1:57pm Add comment
