SPENCER
asked Sep 3, 2015 at 10:27am
Epson Epson Stylus Photo 1400
fatal error code 0x02
My Epson Stylus Photo 1400, after initializing(the usual print head movement when switched on) finally stops at home position then produces a "grinding " noise with the timing belt shaking, and the ink and paper lights blinking continously. Connected to the computer, WICRESET software says " Fatal error code 0x02 motor drive fatal error (CR)
Judging by this prior post on the forum http://www.fixyourownprinter.com/posts/77131 I would tell you to spare yourself some grief and expense and buy a new printer. Epson only sells parts to authorized service centers and by the time you get done dealing with one of them, you could have bought a newer model.
by moe on Sep 3, 2015 at 12:43pm Add comment
there's a white dial on bottom right of printer with an arrow stick a flat head in there screw driver and twist it you might have to take off the case .
by bgknoccout on Nov 7, 2015 at 1:05pm Add comment
